Oil pan gasket? - FirebirdV6.com/CamaroV6.com Message Board
Oil pan gasket?
  • Oil pan gasket?
    I noticed a small oil leak and it looks like it's the gasket. Is this common in our cars, or is it probably something else? Thanks.
    94 Firebird 3.4 - RIP<br />97 Firebird 3.8 - In the works
    its probaly the rear main seal does it look like it might be coming from above the oil pan
    1999 Firebird 3.8 Chamelon<br /><br />MagnaFlow Catback<br /><br />Devon
      well for one, a rear main leak is not a small leak ;) it is probably your oil pan cause the rear main would poor oil, not leak [img]tongue.gif[/img]
      2000 3.8 A4 Pewter Camaro
        Thanks guys. Yeah it's a very small leak. Maybe a few drips a day. Not a priority, but I know its there so it dives me insane. Thanks again. [img]graemlins/banana.gif[/img]
          yeah, if its a small leak like you said, i would let it go for now cause its a pain to replace your oil pan gasket. quick Q? did you recently replace your oil with synthetic?
            well when i pulled my engine it had always been leaking a litte drop of oil ever know and then and it was the rear main it had a little hole in it which cuased it to so you never no
              Havent changed it yet, doing it this weekend (just recently got the car), it's at 80k now, and it's had synthetic for most of its life.
                ok, just wondering cause going from oil to synth. can cause buildup to be pretty much washed and cause leaks. therock, i know its possible but im just saying most of the time, it poors oil. [img]smile.gif[/img]
                  I had a small leak a long time ago, all I had to do was tighten the bolts on the pan, they were a little loose. Fixed the problem.
                  <a href=\"http://photos.yahoo.com/bethann375\" target=\"_blank\">http://photos.yahoo.com/bethann375</a> <br /><br />1999 firebird, dark blue metallic, 5-speed, t-tops, kenny brown sfc\'s, high-flow cat, dynomax super turbo muffler, K&N filter, silver Firebat decals
                  • 187shark
                    by 187shark
