I posted a while back about denting in my front subframe with jackstands. That I am not worried about, it's not that bad. Problem is it has creaked ever since. Right under the driver's seat, from the floorboard, it creaks a little every time I come to a stop. Anyone else have this problem? Can I fix it, or just crank the stereo?
Underbody creaking
hmmm...maybe some subframe connectors would take care of that<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
have a friend push on the car and make it rock until you hear that squeeking and look to see if you find anything rubbing. I had a similar problem and I came to find something was rubbing against my lower controle arm and go from there. Mine was a lil fix just had to get some big pliers and bend the part of the frame that was rubbing away.
mine started creaking AFTER the subframes.. :(
of course I haven't bothered to figure out what it is yet either...-Brad
2000 V-Star Custom 1100
:rock:
