ok i have a electrical problem - FirebirdV6.com/CamaroV6.com Message Board
  • ok i have a electrical problem
    All of a sudden the other evening i noticed that all of my instrumentation panel lights were not working. i had to turn on the interior lights just to be able to see my spedo and tach. also my driving lights (not brake lights) in the back do not turn on. is there a fuse that might have been blown that controls all of these things. i need to get it fixed because its a hazard to drive without those lights
    1996 White Camaro 3.8<p>y87 package, SLP CAI, Taylor Spiro wires, Rapidfire plugs, blackouts, one kick *** stereo
    Yea, inside the fuse box on the side where the driver's door is, there should be an accessory fuse, check that.
    1998 Arctic White Camaro<br />3.8L V6 M5<br />Flowmaster 80 Series with 3\" tips<br />Whisper Lid w/ K&N<br />Flowtech Cutout<br />Free-Ram Air Mod<br />Blue Underbody Neon Kit<br />3 MTX 6000 10\" Subs<br />Rockford 800a2 Amp<br /><a href=\"http://photos.yahoo.com/jeep327\" target=\"_blank\">My Camaro</a>
      Hey beany...I hadnt seen your post..so i just posted also. But I have the exact same problem on mine. But I already tried replacing the fuse but it burns it instantly as soon as you turn on the lights, so i think its a short somewhere. Try to replace the fuse on yours to see what it does. Take off the fuse panel cover on the left side of the dash when you open the door and replace the on that says IP Dimmer. It takes a 5 fuse. If it was a normal fuse burnout it should work normal as soon as you replace it..but if it keeps burning it out you have a short somewhere like me. Please let me know if you are lucky with anything. Thanks.
      <b>.::[ 0 ]::.</b><br /><b>1997 Camaro 3800 II M5</b> (30th edition)<br />[]B&M Ripper Shifter<br />[]Proform Shift Light<br />[]SLP Cold Air<br />[]Dynomax Exhaust<br />[]Richmond 3.73\'s<br />[]Zexel-Torsen LSD<br />[]180* Thermostat<br />[]Tail Blackouts<br /><a href=\"http://photos.yahoo.com/skyracer_x\" target=\"_blank\">pics</a>
        Oh and I forgot to tell you..also replace the one that says Tailights I think to fix that rear light problem. I think it takes like a 20 fuse. Check your fog lights I bet you they dont turn on either. I think they are controlled with same fuse as the those lights you were talking about. Because I know it burned mine out also..And i replaced it. That one works now..but my dash lights are still out.
        [ June 03, 2002: Message edited by: marco ]</p>
          I have the same problem with my dash going on in my Firebird, but none of the fuses are blown, and there's no short. Any more suggestions on how to fix it?
          F-body chicks ROCK.
            I had the same problem about 2 weeks ago. When I turned the lights on, the inside, the fog lights, and the back lights went out. I took it to the dealer and they told me I needed a new light switch. They charged me $80 to find the problem, $80 to fix it, and like $50 for the switch. (I checked everything like 5 times before I took it to the dealer, but everything else was good, so I gave up)
            Sounds like the same problem that all of you are having. If you can get a new switch, you should be able to do it yourself.
            <a href=\"http://www.cardomain.com/id/hpn2003\" target=\"_blank\">www.cardomain.com/id/hpn2003</a><p>SLP cold air intake, B&B cat-back exhaust w/ quad tips, SLP subframe connectors, Eibach lowering springs and Bilstein shocks, Hotchkis Panhard Rod, Hotchkis LCA\'s, Taylor Spiro Pro wires, 160* thermostat, Optima battery, white face gauges w/ carbon fiber trim, carbon fiber/chrome pedals, Avital alarm w/ DEI Remote Start
              Ya know know I think Chevy hired a bunch of monkeys to assemble our car :mad:
                <blockquote>quote:</font><hr>Originally posted by camaroincal:
                Ya know know I think Chevy hired a bunch of monkeys to assemble our car :mad: <hr></blockquote>
                hey even my dads Acura has the same problem [img]redface.gif[/img]
                  Ok the problem I have is obviously electrical as well and falls under this topic.
                  Over the years I have replaced about every external light bulb cuz they keep blowing for some reason. I have also noticed when I brake my "juice" gauge goes down sometimes and then goes back where it was before.
                  New Battery?
                  New Alternator?
                  Fuses?
                  Or Other?
                  Comments Suggestions would be VERY helpful thanks.
                  Mike
                  K&N Air Filter<br />Magnaflow Exhaust
                    I hope this helps:
                    I had the same problem....some stupid@ss put the wire to the center console light right next to the hand brake. Therefore when you move the handbrake up or down the fuse shorts. It took me 40+ hours to find that.
                    Check your wire, you may find a small knick in it.
                    Hope this helps
                    Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
                      <blockquote>quote:</font><hr>Originally posted by Vix2g:
                      I have the same problem with my dash going on in my Firebird, but none of the fuses are blown, and there's no short. Any more suggestions on how to fix it?<hr></blockquote>
                      Ok, so I took my Bird to the shop and turns out that one my fuses was blown. I overlooked this tiny 5A fuse that was the "IP Dimmer". I thought it wouldn't have anything to do with my gauges but I guess I just thought too hard ;) Anyway the repair was only $16, but I figured I'd post my results anyway.
                      F-body chicks ROCK.
