On the passenger side of my motor towards the front i push the hose in untill it clicks over the outlet, then i slide the white cap over it and coolant drips out of it, does anyone have any ideas how i can fix this? I was going to spread some silicone on it and hopefully that would stop the leak.
one of my heater hoses leak coolant any ideas how to fix it?
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
