Jet Chip Stage 2...WTF?! -*UPDATE* -more confused.. - FirebirdV6.com/CamaroV6.com Message Board
  • Jet Chip Stage 2...WTF?! -*UPDATE* -more confused..
    I have the Jet Chip Stage 2 in my car..and tonight I found my self asking..why?
    I paid over $250 thinking it would adjust my shift points..and more importantly..remove the governor!
    Well..I've never topped out in my car since I got it installed, and I've had it for months..Today I was on some country roads..so I thought I would test it out..I punch it..and the speedo QUICKLY climbs to 115 MPH ( 3.4 = 115 MPH ) Once it hits 115 MPH, the RPMs drop and the entire car 'bogs' and automatically slows down..The tach wasn't even near redlining either..SO WTF??? What the hell does this chip do? I was, and still am pretty mad after discovering this today. I was thinking about Nitrous soon, but what's the point if I couldn't break 115?
    Any ideas of what I should do? And how I can remove the governor? Tomorrow, i'm going back to the place I bought it from, and ask them about it.
    [ July 01, 2003: Message edited by: Camaro_SLP ]</p>
    94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
    Sorry to hear it. I have warned people in the past, that those things are a waste of money. People are way better off, putting their money into another mod.
    I would try and get your money back, cause those things are crap.
    Cardomain
      <blockquote>quote:</font><hr>Originally posted by Camaro_SLP:
      <hr></blockquote>
      I don't know a lot about nitrous, or how the Jet Chip works, but I'm pretty sure that nitrous+Jet Chip=bad things happening. Doesn't it advance the timing some?? Advanced timing and nitrous = blown motor. I doubt your going to top out in the 1/4 with nitrous unless your going to be putting one massive shot on. Look at James, he runs 12's and doesn't even hit 115, and he has the 3.8L
      As for removing the speed limiter, see if someone can reprogram your PCM. That is pretty crappy that it doesn't remove the governor, maybe it's not installed right??
      [ June 29, 2003: Message edited by: camaro_speedemon ]</p>
        Hey man, sorry to hear that you didn't get what you thought you were getting. Check this place out. fastchip They have one that will remove the limiter, if that is all you want. I would try and keep the Jet and have this also, if it is at all posible.
        Rob
        \"A one that isn\'t cold, is scarcely a one at all\" <a href=\"http://www.homestarrunner.com/sbemail.html\" target=\"_blank\">Strongbad</a>
          #1 You must be mistaken because the speed limiter on the 3.4's is 110.
          #2 Jet doesn't promise to remove the speed limiter so I don't know where you got that idea.
          1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.
            I love my JetChip. My limiters removed. :cool:
            2000 V6 Camaro(bought brand new)
            5 speed
            Project: Unreal
            Several Mods..:naughty:plus Nitrous=WEEeee:banana:
            2007 Suzuki GS500F :D
            Daily driver
            2007 Chevy Aveo 5
            Mods K&N air filter:excited:
            www.guardiansworlds.com
              Jet chip probably increases trans line pressure and plays with the MAF signal a little.
                <blockquote>quote:</font><hr>Originally posted by Magnus:
                Jet chip probably increases trans line pressure and plays with the MAF signal a little.<hr></blockquote>
                It's been a while for me but I don't think the 3.4s have a maf sensor. I think they work on MAP only.
                1995 Camaro 3.4 v6. Dead<br />1995 Trans Am FIPK.
                  3.4's didn't have a MAF. The PCM module just controls the air/fuel mixture and if your lucky adjusts shifts via pressure.
                  Definitley not worth the money IMHO. But, the speed limiter should not have any bearing on whether you get nitrous or not.
                  If it's a 94 the speed limiter is 105. On the 1995 models when the 3.8 came out mid year the limiter was raised to 115 MPH
                  94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
                    well im not gonna get a chip now...
                    New:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
                      Ok..last night on the highway, I gunned it and watched the speedo. I was very pleased with the results..The needle passed 115 MPH and I just burried the speedo..It was burried for a good 7 seconds, so I adjusted my eyes to the tach..my RPMs were climbing higher, and higher,,and then hit the redline..THAT's when my car bogged,,and the RPMs fell and I slowed down..
                      Now I need some clarification..
                      1) What's the difference between the governor, speed limiter, and rev limiter? I think the governor and speed limiter are the same thing..
                      2) Is there a way to remove the rev limiter?
                        <hr></blockquote>
                        1. A governor is a mechanical device that limits the top speed. A speed limiter is the electronic equivalent to the governor. Its built into the PCM.
                        2. PCM reprogramming. Just remember the rev limiter is there for a good reason and probably shouldn't be messed with unless you've upgraded the valvetrain components.
                        ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
                          So did the Jet chip give you any SOTP gain. My car gets stuck @ 110 and really won't move farther. Is this a good mod?
                          1993 Pontiac Firebird 3.4L V6 A4<br />F41 RPO suspension option<br />119K miles<br />Fastchip<br />K&N \"Filtercharged\"<br />Airbox cuttout CAI<br />ASP underdrive pulleys<br />Pacesetter Headers<br />Flowmaster 80 Series 2.75 cat-back<br />MangaFlow Hi-Flow Cat<br />Corvette Servo<br />16.4 @ 81 MPH
