Firebird Bogging Down?? - FirebirdV6.com/CamaroV6.com Message Board
  • Firebird Bogging Down??
    Ok here is my problem im sure this is common or hope it is...Car runs great untill I give it full throttle or even half throttle at start or when im going fast all of a sudden on the highway..When I step on it bogs down and studders for a few seconds then it will take off.What could this be..It has brand new plugs,wires,fuel filter,and pcv valve ..What the world would cause this!
    Maybe it is running to rich or lean?
    2000 Pewter Pontiac Transam 360rwhp, 370ftlbs
    1998 Sport Gold Metallic Chevrolet Camaro *SOLD*
    1974 Silver Chevrolet BIG BLOCK Corvette
      I had the same problem, could be your ignition coils or ignition module. I eventually had a misfire code come up, but not immediately.
      <a href=\"http://photos.yahoo.com/bethann375\" target=\"_blank\">http://photos.yahoo.com/bethann375</a> <br /><br />1999 firebird, dark blue metallic, 5-speed, t-tops, kenny brown sfc\'s, high-flow cat, dynomax super turbo muffler, K&N filter, silver Firebat decals
        Check your O2 sensors, Mine are causing my car to do the exact same thing...
          vacuum leak maybe? vacuum leak cause the hesitation and can do the shuddering
          2000 3.8 A4 Pewter Camaro
            check your ignition coils definitely...
            could be a clogged/broken up catalytic converter as well...
            2011 Camaro LS 6M, in black.
              When was the last time you changed your fuel filter? Could very well not be the problem, but mine did the exact same thing, only reverse of yours. Under light-medium throttle, it didn't want to go at all. Still, it doesn't hurt to change it
              2000 silver A4 Camaro<br />Whisper lid; Free Ram Air; BMR stb; MSD super conductor wires; Gatorback belt?<br />1986 RX-7 (daily driver)
                I would be running a fuel pressure test if I was you.
