Ok here is my problem im sure this is common or hope it is...Car runs great untill I give it full throttle or even half throttle at start or when im going fast all of a sudden on the highway..When I step on it bogs down and studders for a few seconds then it will take off.What could this be..It has brand new plugs,wires,fuel filter,and pcv valve ..What the world would cause this!
Firebird Bogging Down??
I had the same problem, could be your ignition coils or ignition module. I eventually had a misfire code come up, but not immediately.<a href=\"http://photos.yahoo.com/bethann375\" target=\"_blank\">http://photos.yahoo.com/bethann375</a> <br /><br />1999 firebird, dark blue metallic, 5-speed, t-tops, kenny brown sfc\'s, high-flow cat, dynomax super turbo muffler, K&N filter, silver Firebat decals
vacuum leak maybe? vacuum leak cause the hesitation and can do the shuddering
When was the last time you changed your fuel filter? Could very well not be the problem, but mine did the exact same thing, only reverse of yours. Under light-medium throttle, it didn't want to go at all. Still, it doesn't hurt to change it2000 silver A4 Camaro<br />Whisper lid; Free Ram Air; BMR stb; MSD super conductor wires; Gatorback belt?<br />1986 RX-7 (daily driver)
I would be running a fuel pressure test if I was you.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...43 minutes ago
