ARE THE STOCK INJECTORS 19LBS OR 22? - FirebirdV6.com/CamaroV6.com Message Board
  • ARE THE STOCK INJECTORS 19LBS OR 22?
    i called the chevy dealer and they said that our injectors dont have a certain number ie. 19lbs or 22 lbs and so on because they are electronic? what do i tell summit so i can get the right fuel injectors for my 96 3.8 camaro? IT SAYS 22 IN THE TECH DATABASE BUT I TALKED 2 KEITH AND HE SAID HES JUST GOING BY WHAT HE WAS TOLD AND THAT HASNT BEEN PROVEN OUR CARS ARE 22 STOCK sorry 4 caps
    All injectors are rated using a specific test method to get the size. The stock size is 22, 19 is undersized for a 3.8. The calculations are in the Technical Database.
    Raven
      Depends on what psi they were tested at. LS1s are rated at 58, ours probably around 50, SVOs at 43.5 and so on. So you could get two different flow rates for the same injector.
        Is that enough flow for our cars, it sounds kind of low? Is there any place that can recalibrate MAS for bigger injectors?
        Arctic White \'02 Camaro<br />3.8, 5spd.
