Worn out Alt Belt? - FirebirdV6.com/CamaroV6.com Message Board
Worn out Alt Belt?
  • Worn out Alt Belt?
    Could my WAYYYYYYYYY worn out Alternator belt affect the way my car is starting up? (making it crank) I am running of ideas here...
    Soon to be Mommy!<br />2005 Honda Pilot EX-L
    is teh belt still tight around the pullies?
      sorta
        sorta?
        so is it loose?
        is it cracked??
          VEEEEEEEERRRRRRRRRRRRRYYYYYYYYYY cracked
          sorta loose
            its called a serpentine belt. It will not affect how well the car cranks, in fact it will simply slip and squeel if its loose. Replace it if it has more than 30K miles on it. If your car is cranking funny have you
            Installed a new fuel filter?
            Changed the plugs?
            Checked the plug wires? changed them?
            Check the coil packs? changed them?
            How's the air filter?
            Ran any fuel injector cleaner through it lately?
            Been on a long trip lately with it? (100miles+)
            2002 5-spd NBM Camaro
            Details: www.1lev6.com
              Change that belt. You said youve tried a lot of other things and youre still having problems.
                I would def get a new belt. I got a Gates, wayyyyyyyy stronger than that gatorback autozone crap. It takes like literaly two minites to do it yourself if you have something to hold down the tension bar thingy
                  Where did you get the Gates belt at? I had the Gatorback but it made so much noise it sucked!thanks for the help!
                  1999 Camaro Hugger Orange 3800 A4 <p>Mods-SLP SS exhaust, K&N, SLP STB, SLP SFCS, 1LE Sway Bars(32/19), 99 C5 Wheels on 255/45ZR17\'s-17\'s on all corners...Non-Y87
                    got it at a local place -lord & sulivan- or somthin like that. don't think they're nation wide. look aroud. or go to the gates website.
