Tach and Speedo inconsistency. - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • Tach and Speedo inconsistency.
    Here are the symptoms.
    Driving on the highway @ about 2500rpm 4th gear (also happens in 3rd); hit the gas to speedup (a little hard to pass or just take off) the rev meter jump up real fast, hear the motor scream a litlle and then it comes down and car speeds up normally .. If i Hit the gas slowly it all works good tho. I should be able to punch it but it starts screaming like a lil b****.
    chaged plugs, wires and a coil pack about 30k miles ago. does it sounds like fuel delivery issue by any chance ?? Help plz.
    Currently i am @ 80k miles.
    [ November 09, 2004, 01:04 PM: Message edited by: Camaro2k ]
    Ummad!<br />2k pewter maro M5. 160 thermo, WhisperLid w/K&N Filter, Jet PCM Stage 2, Free Ram Air, Air Silencer Delete (purchased already and) waiting to install manual fan switch, air/fuel ratio guage.
    Checked with mustangeater.. looks like clutch is going ... this blows ...
      I had the same thing on my 3.4L Put the car in 3rd gear and go about 25 mph... then hit the gas, if the revs goes up before the speed, it's your clutch.
      \'97 Camaro 3.8L
        sounds like the clutch to me too :\
        2000 3.8 A4 Pewter Camaro
          i'ma move this to drivetrain, you'll get more help there [img]smile.gif[/img]
          2011 Camaro LS 6M, in black.
