massive cam+ open longtubes+ 2:00 in the morning= ..... - FirebirdV6.com/CamaroV6.com Message Board
  • massive cam+ open longtubes+ 2:00 in the morning= .....
    Girlfriend running down to garage saying your moms nick nacks are vibrating off the shelf :D
    i ran my car open headers before the longtubes and cam and it sounded like sh**
    now it honesty sounds like a freaking all out cammed choppy azz drag car
    a few buddies came over and were like " ah you dog you said you built up your v6" i was like i did and they thought i swapped an lt1 in.
    after a good while my buddy wanted me to spin the tires , well before all the work with just sitting still and punching it i could spin about 15 feet, if i powrbraked of course farther, well i didnt powerbrake last night i just slammed the gas down and it spun both tires well over 100,honest to god
    it stopped spinng when i let the gas off and my buddy was like damn dude i thought you were gonna lose it it was fishtailing real sideways
    i heard james and stefans and even some guys on the board with cams and by far mine sounds the best honestly, i am not being an a** or gloating and i am not takeing anything away from anyone elses cars every one i heard was just simply amazing and imopressive. i think these longtubes sound so good.
    at first i had no power we found that a ground wasnt on then the starter wouldn work well my buddy went and used a screwdriver to jump the starter and when it fired it scared the crap out of him, he was like holy sh** it doesnt sound like a v6, after 2 minutes my gf came down and said holy crap its rattling your moms nicknacks off the shelf thenmy dad came down at 2 o clock in the morning and was all smiles and i asked if moms nic nacks were rattling off the shelf he was like ****.... it rattled me outta fu**in bed and said he couldnt believe how good it sounds.
    i wanna call someone who has a mic and will post it so i can get them to record the sound then this
    kid with the mustangs dad was out and i idled past his house and he yelled stop, made me pop the hood and prove i didnt put an lt1 in, he was like how the hell can a v6 sound better than my boys v8, thats just insane. I need to get my mufflers on and they should be here by friday and iy should sound really good [img]smile.gif[/img] We ran in to a few little problems, my one heater hose wouldnt stop dripping antifreeze and when the idleing calmed down and started chopping the heater hose popped off, so we are gonna try some silicone to stop it from dripping, it looks like a o ring should be on them but the dealer said no. then it rattled a ground loose and the car shut off, i turned the key and my fuel pump wouldnt come on, i got real worried then my buddy said about the ground being loose so i tightened the bolt and everything works fine now. I am really happy, finally happy with my car and i cant wait to run some times, ive waited over a year to get all this going. i have some minor things to work out , i really need some good close pics of the passenger side vaccuum lines for a 96 camaro :( , after all the long hours we put in the other night i went to take it for a spin and when i touched the gas it felt like the rearend was messed up and i immediately stopped and looked at my buddy and said, " were a couple of dumba**es" he was like " ah the torque arm" :rolleyes: oh well i guess you miss a couple things sometimes, its all good now. this edge converter seems good but it only brake stalls to 2400-2500 then the tires brake loose, i called andre and he said just run it at the ttrack and it is a 3600 converter and when i run drag radails it will stall higher andhe says this converter will work best when flashed, he also said he will restall it if i run bad numbers or if i want him to but he doesnt want to sacrifice top end and i will probably lose atleast 7 mph so i should keep it the way it is, i do trust him and i cant wait to hit the track, sorry this is so long guys.
    Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
    holly ****. paragraphs are your friend. of course your open longtubes sound better at idle then the other cammed guys, because they are running through full exhaust and its quiets it down SIGNIFICANTLY. you just stated that, so yeah of course right now yours sounds meaner.
      Thats cool man, it sounds like you finally got everything up and working right. But please somewhat proper writing technique ;) That is soooo hard to read.
      For you leaking heater lines, are you talking about the ones on the top left (passengers side) of the motor that go into the heater core? If so, they NEED O rings. I had one of those lines blow on me, and I repaired the line with a piece of metal pipe :D , but I was leaking a small amount of antifreeze at the connectors. I finally pulled them off again and I don't remember an O ring being on, but it could have fallen off, it was dark when it happened. But my dad suggested to try one. Well needless to say it fixed the problem. :D
      [ July 02, 2003: Message edited by: camaro_speedemon ]</p>
        I was going to try o rings but this dumba** kid that works at a chevy garage said they dont have o rings in it and if i use them it wont work. I will definately try it, sorry about the paragraphing :(
          i haven't been following any of this, but.. what long tube headers? custom?
          and congrats. i bet this thing pulls nicely down the track.
          \'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>
            I guess you could call them custom, i know fabricating the exhaust feels custom [img]smile.gif[/img]
            Havent taken it to the track but it pulols hard, i have no traction at all.
              I see you live in PA, anywhere close to DE? I would love to see and hear your car in person.
              2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
                Where did you get these longtubes?
                Justin<br /><a href=\"http://www.bass482.com/firebird/index.html\" target=\"_blank\"> 2000 Black Firebird A4 Y87<br /></a>170.2rwhp/203rwtq (SAE Corrected)
                  whats the zipcode and address in delaware i can check mapquest to see the driving distance, i got these off a banned boar member who got them off an a** hole who wouldnt give me any info what sorever
                    217 Hillview Ave. New Castle, DE 19720
                    If it is not to far you can come over my house and i coul record the sound for ya. ;)
                      or we can make a nice cruise up there...
                        hey if somebody is making a trip up to PA include me in on that...im ready
                        96 3.8l green camaro Y87 <br />(Sold January 28th, 2004) New whip (02 Civic SI)<br />\"Out with the bad..in with the good; out with the bad in with the good!\"<br /> <a href=\"http://members.cardomain.com/themeangreen6\" target=\"_blank\">http://members.cardomain.com/themeangreen6</a>
                          you with the 96 3.8 you have to come lol, i need to check out your vaccuum lines to make sure mine are hooked up right. Today i got the bullets i ordered from summit, the cool thing is they charge 19.95 for one day air and i said just send it regular shipping and i ordered them yesterday so they got here in one day anyway. now im waiting on the x pipe that justin sutton told me he mailed out last friday because he got the money thursday, now he wont email me back :( but anyway that would be cool if some of you came up here, i still need a bumper cover that im ordering today to complete my car, well now i guess i need some drag radials :D
                            Where are you located and how far are you from my house? If it is not too far then me and the DE peeps can ride up there and check your car out. Shoot me an E-mail: toast520@juno.com
                              hehe....
                              thats not mean... try having a massive intake leak at 4am, with an open Y-pipe on a 3.4L, nothing like a 4500 rpm idle to please the neighbors while I try to find the leak [img]smile.gif[/img]
