HELP with stuffing engine in car, doesn't fit! - FirebirdV6.com/CamaroV6.com Message Board
  • HELP with stuffing engine in car, doesn't fit!
    We tried to put in my 3800 last night and it just wouldn't clear between the k member and the cowl. We tried every angle and even tried to force and all we accomplished was bending and breaking the metal underside of the cowl and it still doesn't fit. Is the 3800 taller than the 3.4 or something?
    Hot Cammed LT1 Sleeper
    are you using the 3.8 engine mounts and K member?
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      I am using the 3.8l mounts with the 3.4l k member. The motor mounts look like they will fit good but we couldn't get the motor in far enough to tell for sure.
        i have no clue the diff. on 3.4 k members and the 3.8's maybe different
        P.S. have you recieved my money yet?
        1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
          K memebers are prolly different..
          and I had to remove the intake manifold on the 3.4 to fit it in, so might have to do the same on the 3.8, just for that extra clearance ;)
            Wow, you're going from a 60 degree to a 90 degree block. I almost expected it to be wider and shorter. Yeah, pull the intake and get that sucker seated. If it gives you problems going back on, start cutting some steel. You can reinforce later.
            \'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
              Matt, i sent you mail
              As for the motor. I only need like no more than another inch of clearance. Do you guys suppose it would b possible to loosen the k member so it drops just a little bit so i can get it through?
                either do that or remove the intake ;)
