SES Light.....Help! - FirebirdV6.com/CamaroV6.com Message Board
SES Light.....Help!
  • SES Light.....Help!
    Ok I did several searches but couldn't find anything that helps. My SES light came on this morning on way to work (stays on) but car was running fine. Went to Autozone after work and they scanned it and got code P0102 - Mass Air Flow input is lower than expected. I forgot to have them clear the code so when I came home I did the PCM reset procedure (turn on ignition, remove PCM BAT & PCM IGN fuses) but the light is still on and now it is sluggish around 3500-4000 RPM. I have only driven it a few miles since. I checked the connections for the MAF and IAT sensors and everything looks fine. Will the light eventually go out and will the car start running better after I drive it more or do I need to replace something? Thanks in advance for any help.
    [ July 04, 2003: Message edited by: jfbird ]</p>
    John<br />98 Firebird,V6,A4,Navy Blue Metallic,Y87, K&N Filter,<br />Whisper Lid, Whisper CAI,<br />Firestone Firehawk SZ50EP P245/50ZR16<br /><a href=\"http://www.fbody.com/members/98navybird/index.htm\" target=\"_blank\">http://www.fbody.com/members/98navybird/index.htm</a>
    Anybody out there?
      take off your intake ducting.. take a q tip and carefully clean off your maf sensor.
      it could be dirty and malfunctioning.
      take off your maf screen see if that will help flow a little more.
      96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
      • 187shark
        by 187shark
