My door has started to squeek. ive tryed spraying some silicone on it and it didnt help.
Door squeek
WD-40 on the metal hinges worked for mine.- <a href=\"http://www.thenebula.com/carpics/pics2/camaro2.JPG\" target=\"_blank\">White \'99 V6 Camaro</a> (M5, 3.23s)<br />- 3\" Borla Exaust, RK Sport Induction Lid, Fast Toys Ram Air, K&N Air Filter, !Silencer, !MAF Screen, B&M Short shifter, Manual Fan Switch, 160° Hypertech Powerstat, BMR Boxed LCAs(rubber/poly), BMR STB<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=386884&page=1\" target=\"_blank\">*My Cardomain Website*</a>
<blockquote>quote:</font><hr>Originally posted by V6MaroFL:
WD-40 on the metal hinges worked for mine.<hr></blockquote>
same here. WD-40 fixes all problems :D1996 Pontiac Firebird: A4, Flowmaster 80 Series, dual 3\" Stainless Steel tips, SLP CAI, Alpine CDA-9813 deck, Infinity speakers, Alpine Type R sub, MTX Thunder 801d amp, Tsunami 2 Farad Capacitor.<br /> <a href=\"http://www.cardomain.com/id/firebirdfury\" target=\"_blank\">http://www.cardomain.com/id/firebirdfury</a>
I use bearing grease. It seems to last longer than WD-40.~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
is your door squeaking through out the whole swing? or is it just squeaking a little bit when the door is almost closed? cause mine did the second. i realized that the door panel was rubbing the front body panel right at the joint. it doesn't do it any more cause it has rubbed off as much as it is going to rub off.2000 pewter firebird<br />Short Throw Shifter, Whisper Lid, Whisper Ram Air, Holley Filter, B&B Triflo, LSD, BMR LCA, STB, PHR, and sway bars (32/21).<br />Power window conversion
<blockquote>quote:</font><hr>Originally posted by Dojo2000:
I use bearing grease. It seems to last longer than WD-40.<hr></blockquote>
Someone once told me to put this stuff on once a year. I have been doing it ever since, and no problems. It works really good.1996 Camaro RS Bright Red<br />3.8L V6 A4 3.42\'s<br />K&N Filtercharger<br />Flowmaster 80 Series Muffler<br />Y87 Performance Package
<blockquote>quote:</font><hr>Originally posted by 5_spd_pewter_v6:
is your door squeaking through out the whole swing? or is it just squeaking a little bit when the door is almost closed? cause mine did the second. i realized that the door panel was rubbing the front body panel right at the joint. it doesn't do it any more cause it has rubbed off as much as it is going to rub off.<hr></blockquote>
That probably means your door hinges need to be tightened because the door is hanging at angle when it shouldn't. Seems like a common occurence because our doors are so long and heavy.~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
How do you tighten the hinges? My doors are squeaking a bit too at times, and it seems like they lean down a bit when I open them. Do you just tighten the bolts going through the hinges or is there some special way to do it? I haven't looked at it any since it's not that big of a deal, but since the topic was brought up I figured I'd ask.AIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
My driver side door hinge started to develop an aggrivating creak too. I tried to pack some White Lithium Grease back in there (did this before I saw this topic) but it wasn't getting to the bearing. I decided that the WD-40 wasn't gonna last long enough to suit me, so I dripped some oil (motor oil) on the hinge. I opened and closed the door about 3 times and then wiped the excess oil off. Cured the problem. You might want to try a product called PB Blaster. I think you can get it at Advance Auto. It's designed to dissolve rust and lubricate, so that might do wonders. The stuff works great on rusty bolts. Oh well, I didn't have any to try. Good luck.~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
PB Blaster, I'm not sure how long it would keep your door from squeakin, but I know it works wonders on rusty bolts. I give it [img]graemlins/thumbsup.gif[/img] [img]graemlins/thumbsup.gif[/img]1999 Silverado- Bagged, colormatched and rollin on stock chrome 16\'s<br />Make love not war, hell do both, get married
