ok, say you have the money for this little assignment. now do you...
A: buy an LT1 for a really good price and with the left over money you bore it out and make it a 383 stroker;
B: buy an LS1 at a higher price and replace the intake manifold and cylinder heads with the stock GM performance parts from a Z06 then have the heads ported; or
C: try to find a reasonable price on an LQ4 6 liter V8 replacing the cylinder heads and manifold with the Z06 parts, swap the oil pan out with an f-body oil pan and if the funds are there bore it out to 434?
overall performance would suggest the LT1 stroker, but the LS1, and LQ4 variant of the LS1, would be the more reliable motors. the LS1 with the new heads and manifold would be comparable to an LS6 and the LQ4 would probably be making some mad power. i think the stroker would be great, but is it really better to go with an older motor?
all accessories will be included with the motor. the most costly of this assignment will be the purchase of the T56 tranny (those things are freakin' high dollar right now). labor has been worked out (we're anticipating the weekend and a few days into the week) as well as the parts to be replaced. everything has been worked out aside from the motor. most parts to be replaced will be new aftermarket parts, other than the driveshaft and the donor motor. at this point it is decision making time. before this amount of money is spent a lot of homework must be done.
one other thing...the motor may get a 75hp shot of NOS thrown in for good measure (but only because the switches look cool).
discreet, low-key, and sleeper status are the priorities here.
and the answer is...
[ April 17, 2002: Message edited by: Domestic Violence ]</p>
