Im gonna finally do it. The Swap. - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Once again, the LS1/LS6 engine will fit. I have personally seen many examples of this. You can even do a search in some car mags. for it. I personally would prefer to have one of the two Ramjet engines since they produce more power.
    1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
    • #17
      if you sell your mods I WANT THOSE HEADERS!!! :D
      let me know [img]graemlins/burnout.gif[/img]
      • #18
        I emailed the guys at HPSALVAGE.COM and they told me that I can definitely fit an LS1 in my 94 3.4 and they never once mentioned changing the whole front end. They do this for a living so I would be more inclined to believe them. Go for it man do the LS1!!!
        Davy Dave
        94 Camaro AT 3.4L<br />Still working on something worth posting.
        • #19
          <blockquote>quote:</font><hr>Originally posted by Skullcamaro:
          Once again, the LS1/LS6 engine will fit. I have personally seen many examples of this.<hr></blockquote>
          i agree. i've seen it myself, as well, and i have the 3.4L motor that came out of it.
          • #20
            If the motor is an LS6, or even an LS1 from a corvette, don't the accesories mount in different spots? The oil pan is also different. It would be cheaper to find a F-body LS1 than convert a corvette LS1 I think. But, if its an actual LS6 than you have no choice. Are the exhaust manifolds different? Also, I don't know what would be necessary to get the corvette computer to work in the f-body. There could sensors that won't match up or are missing, don't know about that for sure though. An LS6 in V6 badging would be pretty sweet if you could pull it off though [img]smile.gif[/img]
            Copied from www.hpsalvage.com Swap Tips:
            LS1
            Requires high pressure fuel pump, 58 PSI, and return fuel line.
            '97 - '98 Corvette LS1 has a pressure regulator and return line as
            part of the fuel rail while the Camaro LS1 has the pressure regulator
            in the tank and only the high pressure line going into the fuel rail.
            The Camaro LS1 can be modified by using the '97 - '98 Corvette
            fuel rail and pressure regulator or by adding an aftermarket inline
            pressure regulator. Only the LS1 4L60E, BWT56 and the '99 and
            newer truck Vortec V8 transmissions will work with the LS1 engine.
            These include the 4L60E and 4L80E for 2WD and 4WD applications.
            A VSS is required for the engine to work properly. A VATS simulator
            must be added for the computer to work.
            The Corvette oil pan has side extensions which could pose a problem in an
            engine swap.
            The specifications page on that website has some basic dimensions as well.
            [ April 17, 2002: Message edited by: Backfire ]</p>
            • #21
              Sorry i havent said a word... but ive been workin. It looks like the ls1 project might start. Im talking to the guy now.. he basically has these things included:
              MAFS, Entire engine, accessories, and computer. Its out of a rolled corvette z06 with 10k. Headers included (brand: the other guys).
              So.. this looks good. i have a 6 speed tranny at the shop and i think i can get it all to work. and yes guys if i get this rolling i will be parting out the ol 3.4. That means all mods for sale. But dont start emailin me yet.. i dont want like 400 emails floodin my box for parts i dont know if im gonna sell yet. Just start claimin in this thread i guess. and tiago has the first dibs on the pacesetters.
              For Sale<p>Mods so Far:<br />Tb Coolant Bypass, NGK Vpower Plugs, Accel 8mm Wires, Gutted Cat, TransAm Muffler, K&N FIPK, Crower Baja Cam, Comp Cams Magnum Rocker Arms 1.52 Ratio, Ported Throttlebody, Ported Intake Manifold, 3.73s and Auburn LSD, Yellow Underbody Neons, Milled Heads, Pacesetter Headers, TransGo Shift Kit, 1 Piece DS, Accel Coils, Rk Sport Air Temperature Module<p>Soon Mods:<br />Nos 5175, Rims, Stage 2 Jet Chip, Jet Underdrive Pullys, Strut Tower Brace, Subframe Connectors, Speed Calibrator, Lowering Springs
              • #22
                hey xfactorx where are you in texas, cuz im from SA just curious, i was considering doing the same thing so i would definately be interested in how things go with this, i know we have the different body styles but im sure alot of the same things have to be changed too...
                good luck
                merlin
                2002 Firebird<br />2003 Yamaha YZF 600R
                • #23
                  Hey xFactoRx:
                  A good place for some additional information on the install/swap is to contact the people at this website www.sdpc2000.com . They are a registered GM seller of crate engines, etc. and from my personal experience have been very helpfull in answering any questions I have about it. The only problem you might have with the LS1/LS6 swap is the oil pan, but that can be easily changed/fixed with some minor modifications. Good luck and keep us updated on how it turns out. I'm planning on putting in my ramjet soon as I get the check from my insurance company. Take care and good luck.
                  P.S. If you have any questions then feel free to email me at nobody2uagain2@aol.com or page me on the message board.
                  • #24
                    Okay, I stand corrected. I was misinformed.
                    Hey Mayhem, **** off. You don't need to be a jackass just because I was wrong and you are right. Some people....
                    Scott
                    [ April 18, 2002: Message edited by: Scott Black ]</p>
                    • #25
                      <blockquote>quote:</font><hr>Hey Mayhem, **** off. You don't need to be a jackass just because I was wrong and you are right. Some people.... <hr></blockquote>
                      Hmm interesting when did i ever say anything about you?? grow up... geez some people....
                      Relax Dood
                      [img]graemlins/fluffy.gif[/img]
                      96 Camaro F1<br />B&B Test Car<br />\"in this world gone mad, we will not spank the monkey, the monkey will spank us!\"<br />Need a V8..\"he might have turetts syndrome we are looking into it\"<br /><a href=\"http://theyetti.cz28.com\" target=\"_blank\">http://theyetti.cz28.com</a><br />was the yetti now MAYHEM
                      • #26
                        LMFAO!!!
                        Yeah, okay, I can forgive you after that little relaxion method. Sorry mang it sounded like you were directin that at me ya know since I was the one saying it wouldn't work..... [img]tongue.gif[/img]
                        Serenity now!!! [img]graemlins/fluffy.gif[/img]
                        Scott
                        • #27
                          no prob now ya owe me a LS1!! :D
