Hey, if all you 3.4 owners want more protection, install an AC Delco filter part number PF52 or something equivlent. Its the same as the regular filter, but about 3in longer. Make sure its an AC Delco or Pure-One or something along those lines, if its a cheap filter it will not have an anti drainback valve, and we all hate that cold start knock.
A Tip On Oil Filters, for all 3.4 owners
Ric Johnson<br />----------------<br />1995 Pro AM III #12<br />3.4 A4<br />KN FIPK intake with ram air mod<br />Flowmaster exhaust<br />RKSport IAT sensor <br />ASP Underdrive pullys<br />TB Bypass<br />PF52 larger oil filter<br />3.42 non posi rear end<br />DeCarbon Trans Am shocks<br />Eibach pro series springs<br />B&M Shift Plus+ (best $40 ive ever spent)<br />Custom made billet alum front end inserts<br />Interior trim painted to match the car<br />Awia CD player with factory bose sound system<br />Viper alarm system<br /><a href=\"http://www.proam.webhop.org/\" target=\"_blank\">http://www.proam.webhop.org/</a>Tags: None
Do you know the dimensions of that bigger filter. I'm trying to see if K&N filets make one similar to it for their gold series oil filters. Thanks in advance.1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
I have a 87 Buick GN and they also have their filter sideways, and its a massive sin if you use a cheap filter without an anti drainback valve. I was thinking, what makes the 3.4 different? Filter sits the same way.. Thats how i also learned the bigger filter trick.. its what ive been doin to my 87 GN for a while now, but it didnt click til last time i changed the oil in the cars.Ric Johnson<br />----------------<br />1995 Pro AM III #12<br />3.4 A4<br />KN FIPK intake with ram air mod<br />Flowmaster exhaust<br />RKSport IAT sensor <br />ASP Underdrive pullys<br />TB Bypass<br />PF52 larger oil filter<br />3.42 non posi rear end<br />DeCarbon Trans Am shocks<br />Eibach pro series springs<br />B&M Shift Plus+ (best $40 ive ever spent)<br />Custom made billet alum front end inserts<br />Interior trim painted to match the car<br />Awia CD player with factory bose sound system<br />Viper alarm system<br /><a href=\"http://www.proam.webhop.org/\" target=\"_blank\">http://www.proam.webhop.org/</a>
