Are coilpacks the same between 3.4 and 3.8? - FirebirdV6.com/CamaroV6.com Message Board
  • Are coilpacks the same between 3.4 and 3.8?
    The reason i ask is because i had a little accident while dropping in the new motor and broke the 1,4 coil pack. I have my old coilpacks off the 3.4 but the numbers are reversed. Would it still work?
    Hot Cammed LT1 Sleeper
    From what I understand, yes; you can swap coil packs between 3.4 and 3.8.
    Josh-
    \'94 Camaro A4<br />Mods: K&N Conical, Dynomax Muffler, Dynomax 2.5\" I-Pipe, Jetchip Stage II, 180 Stat, RKSport Underdrive Pullies, Fan Relay Switch, Rapidfire Plugs, Bosch O2s, Goodyear GA, Aluminum Driveshaft, Alpine CD... <p>And also: Ported and Polished Plenum, Ported and Polished Intake Manifold, Ported and Polished Heads, 5 angle valve job, Raised Compreshion, Tranny Cooler, 19lb injectors, no new times yet.<p>\'95 Dodge Stealth M5<br />stock as a rock...
      Yes, I lloked up the part numbers at Kragen, and they're exactly the same. I was going to use one of my 3.4 coils for troubleshooting.
        Great, thanks for the help.
          coils are the same for pretty much all waste spark systems gm makes.
          ASE Master, L1, X1, C1. Instructor in automotive systems. 99 3800 4L60E with a few mods and a greatful dead sticker on the back window.
