The reason i ask is because i had a little accident while dropping in the new motor and broke the 1,4 coil pack. I have my old coilpacks off the 3.4 but the numbers are reversed. Would it still work?
Are coilpacks the same between 3.4 and 3.8?
From what I understand, yes; you can swap coil packs between 3.4 and 3.8.
Josh-\'94 Camaro A4<br />Mods: K&N Conical, Dynomax Muffler, Dynomax 2.5\" I-Pipe, Jetchip Stage II, 180 Stat, RKSport Underdrive Pullies, Fan Relay Switch, Rapidfire Plugs, Bosch O2s, Goodyear GA, Aluminum Driveshaft, Alpine CD... <p>And also: Ported and Polished Plenum, Ported and Polished Intake Manifold, Ported and Polished Heads, 5 angle valve job, Raised Compreshion, Tranny Cooler, 19lb injectors, no new times yet.<p>\'95 Dodge Stealth M5<br />stock as a rock...
Yes, I lloked up the part numbers at Kragen, and they're exactly the same. I was going to use one of my 3.4 coils for troubleshooting.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
