ses - FirebirdV6.com/CamaroV6.com Message Board
ses
  • ses
    If I install a 180 drilled thermostat, is my ses gonna come on? greyman said to keep my old one in case. I have no way to turn it off, and I don't want to go to the dealer with it. Anyone? It should be here sat.
    Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
    no, it shouldn't.
    2011 Camaro LS 6M, in black.
      no, i put a 170 in and nothing happened. 10 degrees isnt much of a temp change at all so you will be fine. it is only around 160 that your combustion changes and your knock sensors and o2s pick up the change. i think few if any have had problems with the ses on the 160 thermo.
      you will be a o k
      96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />&gt;&gt;&gt;15.375 @ 89.27&lt;&lt;&lt;NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
