If I install a 180 drilled thermostat, is my ses gonna come on? greyman said to keep my old one in case. I have no way to turn it off, and I don't want to go to the dealer with it. Anyone? It should be here sat.
ses
no, i put a 170 in and nothing happened. 10 degrees isnt much of a temp change at all so you will be fine. it is only around 160 that your combustion changes and your knock sensors and o2s pick up the change. i think few if any have had problems with the ses on the 160 thermo.
you will be a o k96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
