My buddy has a 2000 Camaro, and his blinkers went out. The interior flasher does not work either, could this be a flasher problem or the socket it self.
I had a similar problem in my 97 but the flasher worked just no the blinker, i changed the sockets and everything worked.
New Toy Red 94 Formula LT1
RT: .0006 60': 1.894 1/8 mile: 8.351 @ 84.89 1/4 mile: 12.974 @ 107.81
crashed Red 96 Camaro 3.8l: 14.91 @ 92.38
The ex wife's Black 98 Firebird 3.8l: 15.23 @ 88.12
If you haven't fixed the problem already then maybe I have a solution...
If one bulb breaks, then the blinker on the same side (Either front or back depending on your situation) will not work. I had this problem with my Firebird. Water leaks into both sockets and causes the bulbs to explode at times. The turn signal light will just go solid when the blinker is engaged the direction with the broken bulb.
Originally posted by Th3 RiCk: If you haven't fixed the problem already then maybe I have a solution...
That's why the first thing I asked him was if he had a bulb out. ;)
