broken need help please - FirebirdV6.com/CamaroV6.com Message Board
  • broken need help please
    the EGR valve broke on the pacesetter headers right under the two bolts.
    What can I do to fix this?? the problem is that the EGR valve complte assembly is hanging.
    and the vacume hose that goes to the motor gto out and the car accelerates two much.
    can I weld it back
    can I just fix the hole on the ceramic coated header
  • Andy H
    Transmission removal help!!
    by Andy H
  • 2.8 Bird
    Abs inop
    by 2.8 Bird
  • fishin
    by fishin
