oil leak :( - FirebirdV6.com/CamaroV6.com Message Board
oil leak :(
  • oil leak :(
    well guys over the weekend it has been really cold(dunno if that has nething to do with it) also i have noticed i have a decent oil leak under my car, the leak is behind the y pipe i have noticed but cant get under the car good enough to say nething else? ne ideas i checked the oil and a lil low but not bad at all, and the oil checked out ok!! i am going to get an oil change tomm. NE IDEAS?
    Hope you read this before you change the oil.
    http://www.camarov6.com/ubb/ultimate...447;p=1#000005
    I had the same type of oil leak and replaced the drain plug gasket. No leaks!
    While your at it, maybe get one of them $2 dollar magnetic drain plugs. I decided NOT to purchase a $50 FilterMag http://filtermag.com/ just to see if metal shavings do get caught in the oil filter.
    I also used Lucas Oil Treatment with 4 quarts of your favorite synthetic during the oil change. It has drastically reduced my oil leak in my Firebird, give it a shot.
    Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
