Does AC rob power? - FirebirdV6.com/CamaroV6.com Message Board
Does AC rob power?
  • Does AC rob power?
    Does AC rob power even if not engaged? Or is it only when engaged?
    100% when engaged. When not, depends on who you talk too, but it aint the lightest thing either......
    2013 Ram 1500 Big Horn
    94 comero 3.4
      just the resistance of the bearing which isn't much. The biggest parasitic drain on the engine is the power steering pump because it has no clutch. Other than that, it's just dead weight, so ditch it anyway.
      2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
        If it is taken off...Must I get the Delete Pulley or can I just get a shorter serp belt and reroute it bypassing the AC?
          shorter belt will work, mine was really tricky cause i don't have to worry about the water pump, and i couldn't find the belt size in any autozone type place around me
            U sayin ditch the power steering? Hows that feel without it and how much power does it rob?
            2000 3800 II V6 Firebird<br />various small mods, bigger stuff later.
              then how are you going to steer?
                A good amount of power is lost to the power steering, you can steer, it's very difficult. I'm planning on getting a manual rack that has a better ratio so it's easier to steer.
                  Wow I deleted the power steering in my mr2!!! But a firebird [img]graemlins/omg.gif[/img] Jesus you probably don't need to go to the gym, just drive your car around.
                    lol , yeah....ummmm.....I think i'll keep my power steering.... :D
                      Hey Nicklz, are you the one that drives the mr2 w/ turbo around Huntington that kicks my *ss all the time?
                      Old Car = 12.679 @ 106.5 on 150 dry shot.
                      New Car = 2010 3.6l 304hp Camaro
                        i'll keep my power steering. 5 speed and no power steering pump does not sound like fun.
                        flowmaster 80<br />catco highflow cat<br />b&m ripper<br />homemade cai<br />accel 8.5 mm wires<br />hypertech 160 thermostat<br />reprogrammed PCM<br />rockford fosgate and sony<br />centerforce dual friction clutch<br /><a href=\"http://www.cardomain.com/memberpage/838896\" target=\"_blank\">http://www.cardomain.com/memberpage/838896</a>
