firebird wont start - FirebirdV6.com/CamaroV6.com Message Board
firebird wont start
  • firebird wont start
    I have a 97 firebird that sometimes will not start up, it just stutters. after waiting for a half-hour it starts. I changed a coil becouse it was not shooting a spark, i also changed the spark plugs and wires but still does the same thing. Also the other day I got in my car and notice the security light was on I tried to turn it on but it did not start it didnt even stutter. could this two problems be related. Can anyone out there help Id apreciated. thanks
    deleted because I don't know how to give good information.
    [ May 09, 2005, 08:58 PM: Message edited by: navyblue2000 ]
    brink<br />1998 White Camaro 3.8L V6:<br />Flowmaster Exhaust<br />No cat (straight pipe)<br />Free Ram-Air<br /> <a href=\"http://www.cardomain.com/id/98camaro98\" target=\"_blank\">http://www.cardomain.com/id/98camaro98</a>
      Originally posted by brink:
      maybe you messed up your distributor some how =x
      *sigh* No distributor on our cars.
      The security light is caused by the chip in your key. Either the chip was wet, dirty, or the wiring is coming apart (kind of common). You can try cleaning the chip with an eraser to see if it helps. If the security light is on, the car is not gonna start.
      The other time when the security light was off, did it just keep cranking? I'd use a spark tester to make sure all the plugs are firing, and check the fuel pressure.
      Matt
      1998 Mystic Teal Camaro M5
      • 187shark
        by 187shark
