I need my freggin horn to work.I think its a fuse.What the horn fuse labeled as? I checked them out and cant find the one for the horn.
Need to get Horn to work
Sorry, can't help you there.
Do you have a Haynes or Chiltons manual, maybe? You could easily check the schematics and find which fuse it goes to.Matt
1998 Mystic Teal Camaro M5
forget the horn and install a speaker/bullhorn thing like the cops have so you can just yell at people :D
i cant help u if u really want your horn to work- i saw a chick with the speaker thing, thot it was pretty cool-RJ \"Like trail mix I\'m a lil sweet but mostly nutty\"<br />Metallic Blue 2001 3.8 Firebird M5<br />FRA,Smoothed Air lid, Homedepot Intake, K&N Air Filter, MSD Coils & Plug wires, Iridium Plugs, Flash Tune, 2.5 Flowmaster Catback.
There's probably not a single fuse just for the horn. You gotta look at the schematics and follow the wiring to see which fuse it uses.Matt
Yes, the fuse is shared with the cig lighter and should be found behind the left panel between steering wheel and door. I had a problem with my horn blowing the fuse every time I used it. Eventually I tracked this down to a worn thru wire. The wire to one horn was touching the other horn. This eventually rubbed away all the plastic and gave a metal on metal contact. A piece of insualtion tape was all that was required to remedy the problem. Now everyone that gets in my way gets a good blast on the horn ;)
