couple of ?'s parts - FirebirdV6.com/CamaroV6.com Message Board
couple of ?'s parts
  • couple of ?'s parts
    how do u know u need a new starter?
    how do u check the fuel pressure?
    how do u test the spark plugs?
    #1 - Hard time starting? No start at all? Thats how...
    #2 - Not sure
    #3 - If they're old or that bad where you would want to check one, you should just replace them...
    My guess is you're having a hard time starting your car?
      Fuel pressure gauge. Plug it into the fuel rail. ;)
      Matt
      1998 Mystic Teal Camaro M5
        3....pull plugs and ground them on exhaust manifold....turn car over and check spark..the whiter or bluer the spark, the better
        flowmaster 80<br />catco highflow cat<br />b&m ripper<br />homemade cai<br />accel 8.5 mm wires<br />hypertech 160 thermostat<br />reprogrammed PCM<br />rockford fosgate and sony<br />centerforce dual friction clutch<br /><a href=\"http://www.cardomain.com/memberpage/838896\" target=\"_blank\">http://www.cardomain.com/memberpage/838896</a>
          but if you have a 3.8, and you are going throught the torture to pull the plugs, just replace them.
