On my car both sides of the intake behind the MAF screen are inaccessible. The right side where it looks like the IAC would be is a plastic plate that's pop riveted in place. The left side is also pop riveted and has some type of sensing unit attached. What is this and why do I not have access. It looks like I need to pull the entire unit off the TB to clean the sensors. Any help is appreciated.
IAC blocked off?
You have a computer controlled throttle body. The IAC is actually the throttle blade itself.Matt
1998 Mystic Teal Camaro M5
I too have thought about this and wanted to ask. What kind of maintenance do we have to perform (if any) on these Electonic or Computer Controlled Throttle Bodies?
Cleaning? Lubrication?
DZNow Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
i have pics of me cleaning my throttle body on my car site here... i highy recommend it to all. DONT TAKE IT OFF TILL YOU BUY NEW GASKET FOR IT, I LEARED THIS THE HARD WAY.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
I just spray a bunch of throttle body cleaner in there. Note with the ETC there isn't a cable to hold it open while you spray - I turn the key to run (engine off) and either put something heavy on the gas pedal or get someone to hold it down while I spray everything out good.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
I was comparing my throttle body to StrtRacer98's. The throttle controls are diffrent, anyone know why, his looks much more complicated. Both of us have the same 97 cars?<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Yeah my setup is different than both of you guys. It really only looks like there's one 10mm bolt holding the whole thing in place. There must be a lip on the bottom that locks it in place. I'll rip it out this weekend. Thanks. Anyone else with a 2002 setup?Have a 3800 but looking for a Z or SS - Pewter, Stick,T-Tops are only requirements...it\'ll come.<br />My kids are always making unauthorized mod\'s in the backseat
Thanks guys. I'm going to pull the ETC off and clean it when I do my lid/cold air, smooth pipe, and K&N filter mods, but gotta wait till it warms up around here (spring).Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
