So lets say a "friend" of mine accidently put this in his turbocharged camaro. How bad would this be?
15W-50 Synthetic Motor Oil
-Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open DownpipeTags: None
Not horrible, but I would run a 30 or 40 in it. No need for a 50 weight. Try a 5W-30 synthetic, it definitely will be sufficient.2002 5-spd NBM Camaro
Details: www.1lev6.com
Originally posted by pivot:
when I had 10w-30 in my car the lifters starting tapping. I had read that it is a common thing when you use anything other than 5w-30.
I don't know where you heard that, but you will notice that most 3.8 f-bodys actually SPECIFY 10w-30 right on the oil fill cap. There's some pre-existing issue there, or you're driving in really cold weather. Running 5-30 won't hurt anything, but it may shear out of grade faster.
As to the original question, you did no harm to anything by running 15-50 synthetic. Worst thing that happened is you probably lowered your gas mileage a smidgeon.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
FWIW: I get my best wear numbers on 5W-30. A good synthetic 5W-30 will not shear vey much under normal conditions [img]smile.gif[/img]2002 5-spd NBM Camaro
5w-30 definately helps during start-up (when most engine damage occurs)flowmaster 80<br />catco highflow cat<br />b&m ripper<br />homemade cai<br />accel 8.5 mm wires<br />hypertech 160 thermostat<br />reprogrammed PCM<br />rockford fosgate and sony<br />centerforce dual friction clutch<br /><a href=\"http://www.cardomain.com/memberpage/838896\" target=\"_blank\">http://www.cardomain.com/memberpage/838896</a>
15w-50 is sometimes used as a diesel oil, but not normally, diesel oil is normally a 15-40, with an "advanced soot control aditive" and even then, it should not harm anything in a gasoline engine-Travis<br /><br />95 Camaro 3.4 M5<br />Pacesetter Coated Headers<br />Catco Cat, <br />Dynomax muffler with custom piping<br />Custom Cold Air Intake<br />B&M Ripper Shifter
A lot of people use 15w-50 oil when at the race track because of the high temperatures and the change in viscosity of the oil at those temperatures and hard work on the engine. The numbers don't mean it is a diesel oil over gas. The number is basically just the cold start rating (first number) and the max viscosity allowed (second number).
If you want to read up about oil, a good article can be found here: http://www.texacoxpresslube.com/carc...viscosity.html<a href=\"http://home.comcast.net/~beer13oy/carpage.html\" target=\"_blank\"><b>1995 3.4 Liter M5 Camaro</b></a><br />A few mods...<br />still slow.<br /><br /><a href=\"http://www.mnfbody.com\" target=\"_blank\">Minnesota F-body</a>
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...10 hours ago
