License Plate Bulb - FirebirdV6.com/CamaroV6.com Message Board
License Plate Bulb
  • License Plate Bulb
    my 01 camaro rear license plate bulb is burt out. I was told by a very nice police officer that it was out and needed to be replaced asap. so I bought the bulb and I undid the connection, but its sealed. Its like glued in there. I was wondering if there was anyway I could get it out.
    I'm in college so I really dont have access to alot of tools, but I didnt think a bulb was so involved. and if that 'glue' was there when I replace the bulb should I reglue it?
    What color is the "glue"? Because they usually cover the contacts with a conuctive paste, since it's exposed to the elements. I'm not 100% sure, since I've yet to change that bulb out, but it should just unplug from the wiring harness
    2000 silver A4 Camaro<br />Whisper lid; Free Ram Air; BMR stb; MSD super conductor wires; Gatorback belt?<br />1986 RX-7 (daily driver)
      its almost the same color as the housing, but more greyish. I tried just grabbing the bulb but it wouldnt come out.
        do firebirds have bulbs back there?
          all cars have too. you have to have the back license plate lit up. those lights come on with your headlights.
            What bulb # is it? Mine is ugly yellowish looking and I'd like to get a more pure white bulb if I could.
              but its still sealed in my harness :/
                i would try to make it as dim as possible so nobody could read it ;)
                  The bulb is sandwiched in a housing - you need to unscrew the assembly from the bumper, then you need to give the base about a 90* twist to get the two halves apart to get to the bulb (a tiny thing). The bulb just pulls out of the socket from there.
                  If there's some corrosion causing it to stick, you might want to try spraying some WD-40 in there to see if it loosens it.
                  2001 Pewter Firebird Y87, M5
                  Go Sabres!
