Got a tranny mount from AutoZone... Got questions... - FirebirdV6.com/CamaroV6.com Message Board
  • Got a tranny mount from AutoZone... Got questions...
    Will it work? Straight forward install?
    It's the $25.99 Energy Suspension Polyurthane mount.
    If you need a part number, it's 3.1108G
    http://www.camarov6.com/cgi-bin/ulti...c;f=2;t=002915
    Matt
    1998 Mystic Teal Camaro M5
      Okay, what am I going to need to raise the tranny up a half inch?
        A jack.
        edit: http://www.installuniversity.com/ins...y_mount_m6.htm
        Matt
          Originally posted by 98Camaro3.8:
          A jack.
          No I mean for a spacer because I found out my tranny mount is supposedly too short... By a half inch...
          Also it seems to come with two brass fittings, would one brass fitting be a spacer?
            Eric said he used a few washers to raise it up. I've read of other people doing the same.
            Matt
              A jack.
              [img]graemlins/twak.gif[/img]
              use a jack and get some old washers or nut to pace it out some more
              www.turbov6camaro.com
              1997 3800 Series II Camaro
                Okay so I should look for about 12 washers, 6 for eachside? Also if I used rubber washers would they hold their integrity and keep the noise down?
