wanting to change out my weatherstipping on a 96 firebird. Any tips on pulling off the old and where to buy the new?
weatherstipping
The old will just pull right off. Dealership will proabbly be the best bet on the new materials.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
weatherstipping where?
I have hardtop door/window weatherstripping, since I now I have t-tops, get technical I also have 2 extra sets of t-top weathersttriping too.
Just pull it off just becarful on hardop there is a screw in the middle of the doorjam on the back side and a plastic pin in middle of hte door in the front by the front hinge.
It just pulls off out of the channel and ease in the new one with a flathead screwdriver.
T-top weahterstripping has 2 more screws on the roof at the 2 corners.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
Are you leaking? Or is there actual visible damage to the weatherstripping.
If you are leaking I can give you some tips to fix it, you probable do not need a new weatehrstripping, just an adjustment.
If its a t-top leak, you will likely have water in the floor pan in backseats and at the bottom of the a-pillars.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
browse this thread a little bit...
http://www.camarov6.com/cgi-bin/ulti...c;f=1;t=014379
if you still need some help just describe where you are leaking...
BTW i think dealer t-top weatherstripping are like over $100 a window, try www.yearone.com I think they sell new ones too.
Or just borwse ebay, I think used ones off ls1 cars(93-02 they are the same, but ls1 ones are newer) go for like $35-70 for a pair.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
well it isn't visible damage, and there is only leaking when I pressure washer directly at the window, a little gets through. However ,there are visible gaps at the back of each window when they are up and there is a lot of wind noise while driving96 Firebird, Ram Air Hood and Airbox, Magnaflow Catback & hi-flow cat, Dynomax Bullet muffler
hmm... where at? between the t-top and window, or the weatherstripping and window.
I have heard of people have problems wth the window track and not have it line up before. I'd try taking off the weatherstripping and putting it back on and seeing how it works.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
Originally posted by whitefirebird96:
well it isn't visible damage, and there is only leaking when I pressure washer directly at the window, a little gets through. However ,there are visible gaps at the back of each window when they are up and there is a lot of wind noise while driving2000 Monterey Maroon Chevrolet Camaro<br />3.8L V-6/4spd Auto
