I was driving along in the horrible SOCAL traffic. And I notice my "Security Light" goes on. I pull over and pull out my OBDII scanner and try to read it. No Codes to read. So I restart my and it does its normal cycle and goes off shortly.
About 3 minutes later, My Check Guage light comes on, and my Oil Rressure is around 20, my temp shooting past 240 and my voltage just a tad low(Could have been because my lights and sterio were on).
I pull over, and let the car sit, and add some water to the DRY resevoir tank. And as soon as I start the car, the temp shoots ups and then falls back to normal at 200-210 and the oil pressure just a little low at 40psi.
But what would cause the oil pressure to drop and the temp to shoot up.
No leaks as far as I can tell.
