Im about to make a trip from San Antonio Texas to Washington DC for the summer. Any suggestions on what to check to ensure a good safe trip?
Long trip checklist?
change the oil, check trans fluid, rear fluid, brake fluid, clutch fluid(if applicable), power steering fluid, coolant level, check brake pads if they look low change them2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
belts and hoses will give you trouble if they're in bad shape. tire psi should also be checked.
