A/C help quick - FirebirdV6.com/CamaroV6.com Message Board
A/C help quick
  • A/C help quick
    I am using the recharg system from the parts store. I have the first can hooked up to the line and it open and the ac is on with the car running. my question is how long does it take to drain the can? I have been out there 15 mineuts. my haynes manual says only disconnect when the can is empty. I have been shaking the can like it said to do on the can(not too hard, duh) but this is taking forever. is it suppose to take this long?
    95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------&gt; <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
    nevermind it finally gave up the fight. but damn, somebody should put a warnigng on the can for when you unhookl the hose, I thought my fingers were going to stick to the can lol
      There is one. It says to wear cloth gloves and goggles whenever you're using it
      2000 silver A4 Camaro<br />Whisper lid; Free Ram Air; BMR stb; MSD super conductor wires; Gatorback belt?<br />1986 RX-7 (daily driver)
        are you using a gauge? or just the hose with the fittings?
        flowmaster 80<br />catco highflow cat<br />b&m ripper<br />homemade cai<br />accel 8.5 mm wires<br />hypertech 160 thermostat<br />reprogrammed PCM<br />rockford fosgate and sony<br />centerforce dual friction clutch<br /><a href=\"http://www.cardomain.com/memberpage/838896\" target=\"_blank\">http://www.cardomain.com/memberpage/838896</a>
          The closer you get to the proper amount of refrigerant in the system, the less pressure difference there will be between the system and the can, so it will take longer and longer for the can to empty.
          But you should be using a gauge to make sure the system has the right amount in it. Too much and you're asking for trouble.
            2 days ago
          • Doodler
            97 Camaro base with expensive sounding noises
            by Doodler
            Still trying to find oil leak
