Info on changing my thermostat? - FirebirdV6.com/CamaroV6.com Message Board
  • Info on changing my thermostat?
    I Dont even know where its located at... Not a clue... just ordered a hypertech 160 for my ryde... I have a 3.4 any help/tips?
    On my 3.8, it's on the drivers side near the rear. It's secured by 2 10mm bolts. Pop off the cover, replace the T-stat, replace the cover, & top off coolant. If your car is anything like mine, the temp gauge won't even register a change! :mad:
    <br /><br /> <a href=\"http://www.cardomain.com/id/nitroxxx28\" target=\"_blank\">http://www.cardomain.com/id/nitroxxx28</a>
      On the 3.4, the T-stat is located right under the throttle body, you'll see a hose running to it, it's not hard to find once u know where to look. Goodluck!
      [ May 10, 2003: Message edited by: 3400Camaro ]</p>
      1995 Camaro 3400 SFI V6 M5<br />Custom CAI|FloPro Exhaust|Mobil 1 sythentic|Yokohama T4\'s| 5% Rear Window tint, 35% front| Hockey stick side stripes|Indiglo Gauges|Custom Painted Interior<p><a href=\"http://www.cardomain.com/id/3400camaro\" target=\"_blank\">www.cardomain.com/id/3400camaro</a>
        The temperature gauges in our cars are horribly inaccurate just like practically every other gauge. The car will run a lot cooler with a 160 tho. www.installuniversity.com gives a pretty good tutorial on how to do it for a newer f-body (its on an LS1 but works for a 3.8) don't know if it will help with a 3.4 tho.
        [ May 10, 2003: Message edited by: Camarorulz ]</p>
        • Andy H
          Transmission removal help!!
          by Andy H
        • 2.8 Bird
          Abs inop
          by 2.8 Bird
        • fishin
          by fishin
