i have had my bird for about a week now, its a 97 with 55,000 miles. when i accelerate hard, there is a rattling sound that comes from under the hood, and when i push in the clutch there is a click sound from under the car. any ideas?
It may just be the heat shield above the cat. Easy fix just get a bunch of hose clamps connect them all together. Put them around heat shield / cat and tighten. If it stops rattling that was it. If not sorry.
how bad is the rattle? Is it predetonation or does it sound like a tapping or a rattle?
One source of a rattle is the Y-Pipe. I am not sure about yours, but my 3.4 has a double walled Y-pipe that came loose at 35K and again at 60K. This make a loud rattle almost like a crap load of predetonation......my first fix was a replacement under warrently...the second was drilling a couple of holes in the pipe and welding them closed (thus binding the two pipes)
The seconed source which is more of a tapping under acceleration is a leak in the EGR.
The third source of tapping is predetonation, which can be hazardous to the engine...but unlikely if you don't have a lot of mods....higher octane gas can solve this issue.
Good luck.
Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
