Window Problems Help!!! - FirebirdV6.com/CamaroV6.com Message Board
  • Window Problems Help!!!
    This just happened on my way home from work. about 1130. I rolled down my window and everything was fine, then i got a call on my cell so i rolled it up really quick. After the call was finished, I rolled it back down, then when I got home it would not roll up and made a "ERRR" (Electrical Sound) noise down by the brake. So i waited about 1 min then rolled it up. I though I would try one more cycle, went down find but stoped 1/3 of the way up. Again waited about 30 sec and rolled it back up. Then I came to the computer and I find my self asking you guys for help. So Can anyone Help me out?
    I think it may be the motor, just want to hear other thoughts before i go ripping my door panel off
    Mike<br /><a href=\"http://www.my99firebird.gq.nu\" target=\"_blank\">www.my99firebird.gq.nu</a>
    it sounds like something is kicking out your relay. so either your relay is going bad or window motor is going.
    also does it do the same thing to the other window? if not i would lean more towards the motor unless ( which i doubt they do) use 2 seperate relays for the windows.
    [ August 03, 2002: Message edited by: Fireman ]</p>
    94 Firebird 3.4 M5 t-top<br />mods: 3.4 aluminum block, big block hood,custom ram air,cat back exhaust,3 JL 10 inch W0 with a 1200 wat legacy amp, legacy 6 1/2 componet set , pioneer 3 way 6 1/2 ,pioneer 730 wat amp.
      its just on the drivers side, ill check out the relay sunday (have to use the AC) where is it located?
