top end cleaning - FirebirdV6.com/CamaroV6.com Message Board
top end cleaning
  • top end cleaning
    was thinking of doing the sea foam route, but heard of people opening holes that were plugged by carbon and making it worse on them. I was thinking of just taking it to the shop and do it, but don't know what places do it and are respectable. Btw, I am about to hit 200K on the car.
    96 Firebird, Ram Air Hood and Airbox, Magnaflow Catback & hi-flow cat, Dynomax Bullet muffler
    wow and its only 10 years old. do you commute 100 miles to work or what?
      I'm also intrested in this, my '95 is nearing 170k. And yes, the previous owner had a 45 mile commute, each way.
      <b>1996 Camaro Z28 M6 Convertible</b> Not stock (<a href=\"http://www.cardomain.com/ride/2055334\" target=\"_blank\">Cardomain</a>) <i>(Wrecked, 3/4/06)</i><br /><b>1995 Camaro 3.4L</b> (<a href=\"http://www.cardomain.com/ride/602057\" target=\"_blank\">Cardomain</a>) <i>(Sold, 8/05)</i>
        I bought it from a guy who travelled all the time on the highway, so he said almost all the miles were put on there. I bought it at 189K so I have only tached on a little ove the past year and a half
          I seafoamed mine at 100K with no troubles whatsoever. But I can tell you it will dirty up your spark plugs and O2 sensors, so you might want to replace those after you change your oil and get the seafoam out.
          2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
            so what in everyones opinion is the maximum safe mileage to seafoam?
            im at almost 107k
            1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
              im at almost 107k
              Maximum safe mileage? The more miles you have, the more you need to do it. If you had real low mileage, it would be a waste of times since very little has built up inside the engine.
              Matt
              1998 Mystic Teal Camaro M5
                So would anyone suggest I take it to a shop instead of doing it myself. I have read the seafoam instructions quite a bit and understand how that works, just didn't know if a lot of people had a bad experience or what?
                  Only bad experiences I ever remotely heard was mixing it in with your crankcase oil.
                  never heard of a problem running it through the upper intake.
                  I suggest doing it and consider taking the TB off and cleaning it thouroughly.
                    does the TB come off by unscrewing some things, or is it more difficult. Instructions would be great. Thanks
                      i understand the concept of seafoaming but like what was said before, i was afraid that the more miles on an engine, the more places where leaks occur woul;d be plugged by carbon
                        throttle body comes off with 3 bolts i believe. I have done it numerous times, its a piece of cake. If you are gonna take it off, make sure you have a new throttle body gasket because it will most likely crack when you take the TB off.
                        1996 Pontiac Firebird<br />Flowmaster Exhaust, Custom Cold Air Intake, 3.42 gears with LSD
                          And a towel to stuff under it to soak up the coolant that leaks out. And don't forget to fill up and bleed the cooling system when you're done. ;)
                          Matt
                            2 days ago
                          • Doodler
                            97 Camaro base with expensive sounding noises
                            by Doodler
                            Still trying to find oil leak
