there has been a small puddle of antifreeze under my car a few times now, i don't know why or how this could happen but i looked up under and it seems to either be dripping on the y-pipe from above, (right where the Y is) or it is hitting one side and running down... is this common/how do i fix it?
coolant leaking from y-pipe?
Are you sure it is coolant? I assume you have actually smelled it..... the area you are describing is also where the A/C condensation drains from under the car. Keep an eye on your antifreeze level... if it does not drop down at all, you do not have a leak.
<blockquote>quote:</font><hr>Originally posted by 98v6:
there has been a small puddle of antifreeze under my car a few times now, i don't know why or how this could happen but i looked up under and it seems to either be dripping on the y-pipe from above, (right where the Y is) or it is hitting one side and running down... is this common/how do i fix it?<hr></blockquote>
Is the fluid red in color? If so, then check your heater hoses. They run to the firewall to your heater core, and one hose may have a leak.
If the fluid is clear, were you using your A/C just before you noticed the leak? Like fenderman said, it may just be condensation dripping down...
-Marcsigpic
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...3 weeks ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...4 weeks ago
