voltage? - FirebirdV6.com/CamaroV6.com Message Board
voltage?
  • voltage?
    Ya'll ever heard of a problem where like i'll be driving with my lights on and A/c on and radio on, and my voltage will like drop for a second then go back up? it only happens when my lights are on. Even if i turn everything else off, the voltage still drops and the lights dimm for a sec then they go back to normal for about 20 minutes. its been happening since i got the car... so i dunno...
    99 WS6
    Originally posted by camaroextra
    tears are great lube, but its hard to get a girl to cry onto her own ***.
    I get this when the electric smog pump kicks on and the headlights are on, but not sure you have one.
      er, pardon my retardness, whats an electric smog pump
      99 WS6
        It's part of the secondary AIR system. It takes air from the intake and pumps it into the exhaust upstream of the converter. Supposed to continue the combustion process of any fuel that didn't get burnt up in the cylinder. Ah nevermind, I think only the 3.4 and LT1 had them.
        Does the charging system warning light come on when the voltage drops? How far does the voltage drop? It only happens when the headlights are on?
          no, no warning lights come on. it only drops to almost the bare mininum then charges right back up... only happens when the head lights are on..
          i have like no idea where to start looking
          99 WS6
            My 95' does something similar to this only does it alot more when the engine and I suppose the alternator has had time to warm up due to engine bay heat. Mine will almost drop to the bare minumum just above the red and actually sometimes stay there but when the engine and everything is cold it stays well in the norm even though it does drop some. Ive always wondered what this could be. My only idea is that it could have to do with the alternator remote voltage sensing wire being in a bad spot but this is just one of my theories.
            1995 Arctic White Camaro. 3.4L/A4<br /><br />\"Stupid men make mistakes, wise men learn from mistakes\"
              This problem has been around for quite some time now and still noone has found a solution. :(
              http://www.camarov6.com/cgi-bin/ulti...c;f=1;t=013535
              http://www.camarov6.com/cgi-bin/ulti...c;f=1;t=012922
              http://www.camarov6.com/cgi-bin/ulti...;f=12;t=002339
              ---Niño---<br /><i>95\' silver 5 spd</i>
                My car has the 'dip' since day 1 (brand new). The voltage drops from normal (about 13.5 - 14V) to battery voltage (12.6V +/-) for about a second or less and then recovers to normal immediately.
                I am 99.9% sure it happens when the engine cooling fans turn on to high speed. I suspect that the voltage regulator on the alternator can't keep up with the sudden load addition.
                I guess they use cheaper alternators in f-bodies compared to Cadillacs.
                Nothing to get too worried about as long as your battery is good.
                2002 Camaro Coupe<br />Navy Blue, A4, Y87<br />Whisper Lid, Raised Air Box<br />SLP Bow-Tie Grill, HPP3
                  Mine has also had the dipping problem since day 1, and I bought it brand-new.
