i agree. its fun, and simple. plus it feels good that you know what has ben done to your car (mantiance wise) and you know it was done right.
Rear End Fluid Change...
Originally posted by V8 Killer:
</font><blockquote>quote:</font><hr />Originally posted by Need4Camaro:
Well, the car has 140K on it now and given I'm the car's 5th or 6th owner... I seriously doubt if this job has ever been done since last I checked it's still running on GM Stock plugs, Wires, Fuel Filter, ect... (I just changed the Fuel Filter, Air Filter, and PCV Valve... doing the plugs and wires today when I get home...)
Given the fact it's a messy job and I need a replacement gasket and a tourque wrench maybe... I'll just have a shop do it... Probably castrol since most of my lubrication products are from them anyway...
Hey will bad rear end fluid make your car seem somewhat sluggish even after it's been tuned up? No misfires or studdering it just seems I could get more accelleration for the pedal I'm giving it... I have tools... where's the filler hole? I'll get under her tomorrow to see what this job will require and I'll consider doing it myself... can someone just run by me everything I'm going to need one more time?
Edit: ALSO!!! Is it safe for me to switch to synthetic gear lube at 140K without leaks? Is GM LSD Fluid nessicary? I believe I saw Castrol selling LSD... OR Lucas, one or the other...
[ February 02, 2005, 01:18 AM: Message edited by: Need4Camaro ]1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
Originally posted by mike h:
what happens if the fluid in the rear end starts to run low? will it lock up/slow down? maybe i could be mistaking this for a misfire, if the rear is locking up it would make the engine lurch, correct?1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
