ok so i have pretty much taken care of my air intake, but what about the other side of the equation, fuel? what can i do about that. and if i go to a forced induction (which it looks like i might) do i need like a bigger fuel pump or anything like that???
ok so
ok so
White \'97 Firebird V6<br />t-tops<br />80 series Flowmaster Exhaust<br />SLP CAI<br />180* stat<br />tinted side and back windows<br />3\" echo pipes/chrome tips<br />headlight conversion kit<br />fog lamps<br />smoke rear and turning lamp coversTags: None
<blockquote>quote:</font><hr>Originally posted by Dan Clark:
ok so i have pretty much taken care of my air intake, but what about the other side of the equation, fuel? what can i do about that. and if i go to a forced induction (which it looks like i might) do i need like a bigger fuel pump or anything like that??? <hr></blockquote>
Depending on how elaborate you want to go with the fuel system, you could do any of the following:
- Fuel cell in back of car and remove the stock fuel tank. (This would be for a drag car only.)
- In-tank fuel pump
- In-line fuel pump
- I have seen a real nice setup on a turbo LS1 that had lines tapped into the bottom-rear of the fuel tank with an Aeromotive high volume pump and Aeromotive high flow fuel filter
- fuel cooler
- bigger injectors
- Kenny Bell Boost-A-Pump/MSD Boost-A-Pump/Aeromotive fuel pump controller
- Adjustable Fuel Pressure Regulator (AFPR)
- Injectors
That's about all that I could think of for the fuel lines/fuel systems. If anyone else has anything to add, please do so.
[ May 12, 2003: Message edited by: viper98885 ]</p>- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
by fishinI usually have to double, triple my headlight switch for them to come up on my 97 Firebird. I cleaned all connections. Could it be the headlight switch...3 weeks ago
