Personal No Start Kill Switch - FirebirdV6.com/CamaroV6.com Message Board
  • Personal No Start Kill Switch
    Hello V6ers and other as well. I would like to tinstall a switch that will not allow that car to start. You can turn on ignition but no cranking. I have a OhOne V6 Firebird A4. Any ideas on a simple effective place to wire the switch in. I can figure out the location of the switch. Thanks
    &gt;&gt;OH 1 FIREBIRD SunsetOrangeMetalic<br />Not at All Stock
    http://www.bfranker.badz28.com/fbody/starterkill.htm
      I should add that there is no aftermarket alarm on the car just what came from the factory the remote keyless entry and the chip on the ignition key.
        The link above describes a starter kill switch totaly seperate from a car alarm. You don't need any kind of alarm to do the that switch. Or you can follow the diagram there from the aftermarket alarm start kill switches.
        ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
          I was fooling around with the idea a few days ago. I found that if you take the guage fuse out of the panel, the car won't turn over. I didn't get a chance to see how hard it would be to hook up a little toggle switch in line with the fuse, but I plan to soon.
          <a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
            if you put a switch on there it could really come in handy... the odometer doesnt work with that fuse removed... just switch it off on the highway after you set the cruise to the speed you want to go...
            99 3800 NBM Camaro - (Xcessive Xcelleration Racing Team)<br />Ram/Cold Air Induction (custom)<br />Modified 4l60e Valve Body<br />Z28 Catback<br />SS Hood <br />Modified 99 GM 3800II <br />JB Performance Engineering<br />jfbperformance@cox.net
