ok.. i have a problem.. my AC works, its just that it only blows at the feet.
if i start it at the slowest speed..and gradually increase it, it will blow through the vents. but once i barely tap the gas peddal, it goes to my feet again. what is wrong? how do i fix that?!
96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
when i turn the ac on in the car.. no matter where i set it. it blows out the window defoggers and at my feet.
where are these vacuum lines?!? there are some that icant follow due to the wire looms. but where do they go to? do i have to take off my dashboard to get to them?!?!
HELP PLEASE!!!!
checked all hoses.. no detatched lines or anything.
guess ill have to be pulling this damn dashboard.
this sucks
remove the passenger side panel underneath the glove box (called kicker panel?) then there are 2 or 3 screws you can take out to take the glove box out. You should be able to see some vacuum lines without the glove box in the way. You'll probably want to go ahead and remove the casing that is way back in there that will give you access to the heater core and one of those doors. I don't think this is the door that has the problem though. I've never dug any deaper into the dash than that so if there are any other doors or lines, somebody else will have to speak up. I'm sure there are.
im in the process of removing the entire dashboard.. just as magnus did.
its kind of fun [img]smile.gif[/img]
hopefully it will all come back together the right way
