I am by no stretch of the imagination an electrical engineer or an electrition.....So I need some help.
My pass side window is going down very slowly but goes up fine...it does not matter which switch you are using, same result. The motor is new so I eleminated that possibility. I suspect the wiring or the relay. Now I looked at the wiring diagram and now I am thoroughly confused. Does the pass side have a relay and where is it? Does the DS signal pass thru the PS switch? Does the signal from both switches pass thru a relay and then go to the motor? If the signal goes from the switches to a realy then to the motor, can I install an instant down like the DS?
Please help. Any advice is very welcome.
