Wiring Help - FirebirdV6.com/CamaroV6.com Message Board
Wiring Help
  • Wiring Help
    I am by no stretch of the imagination an electrical engineer or an electrition.....So I need some help.
    My pass side window is going down very slowly but goes up fine...it does not matter which switch you are using, same result. The motor is new so I eleminated that possibility. I suspect the wiring or the relay. Now I looked at the wiring diagram and now I am thoroughly confused. Does the pass side have a relay and where is it? Does the DS signal pass thru the PS switch? Does the signal from both switches pass thru a relay and then go to the motor? If the signal goes from the switches to a realy then to the motor, can I install an instant down like the DS?
    Please help. Any advice is very welcome.
    Joel<br />God is my copilot, but Satan has his foot on the gas!<br />94 3.4L AutoCamaroRagtop w/MSD ignition,Accelcoilpacks,K&N FIPK,BMR SFC&STB,3\"Catco w/3\"catbackSS muffler,JetStage 2,HomemadePIAAheadlightconversion <a href=\"http://www.geocities.com/cardiac1968\" target=\"_blank\">http://www.geocities.com/cardiac1968</a>
    well i might not be much help but, I just installed power window in my car and it doesn't have any relays between the switches and motors. If it has relays before the switches I don't know where they are.
    2000 Camaro 3.8 v6 M5
    Flowmaster 80 series muffler, B&M ripper shifter, SLP grille
