Have any of you guys ever done this? I sort of want to do this so I could make room for a one gallon container that I'll be using for the alcohol. Since I can't find any room for it, I thought I mightness well move the battery. I certainly don't want to put the gallon inside because it would start to smell like alcohol. But how hard is it to put the battery in the back? Or, is there another option I could look at
ALCOHOL?!?!?
(say what?)
-must be used for moonshine runs to West Virginia I assume ;)
Well there is a kit, I have seen it before, or you could just build a simple little box, that drains the outside, and buy some battery cable to run to the front of the car.
Jared W. Drummond<br />jdrummon@vt.edu<br />1997 3.8 Firebird M5<br />-----------------------------------<br />*Flowmaster 80 Series Muffler* *SLP Cold Air Intake* *Zexel-Torsen LSD* *1-Piece DS* *Eibach Pro-Kit* *Removed MAF Screen* *Manual Fan Switch* *Mobil 1 Oils*<br />-----------------------------------<br />*Pioneer Premier DEH-920R Headunit* *Orion Cobalt 6 1/2\'s* *Sub Stealth Box w/ Alpine SWR-1021D* *Kenwood 728S Amp for Sub*
Have you guys seen the dynobatt battery that is on Thunder Racning. I think the battery only weighs like 12 or 15lbs. That could shave off over 15lbs. Anyone tried it?
