Ok how do I get this som b!tch out? I need to remove it in order to remove the passenger side valve cover. I removed the one bolt I could feel back there. Got back on top of the engine and its acting like its either wedged, welded or another bolt that I can not get to is back there holding it on. Where is the mystery bolt?
back dog tooth
Originally posted by 98_birdman:
not sure what a dog tooth is....but all i have to say is good fuggin luck getting that engine hoist bracket off of there....there are 2 bolts...one you can feel...the other you cant unless you've got arms like a 3 yr old
Where is the second bolt? I got the obvious one out already and that wasn't the easiest either. You do have to remove the hoist mount don't you in order to get that valve cover off?
God what happened to the SBC days...valve cover off in less than 2 minutes.-1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
Yes, the bracket has to come off to get to valve cover off. I don't believe it's connected to the valve cover, you just can't get that bolt on the cover to get it off unless you remove the bracket.
http://www.leadingedgesim.com/mkapro...iftBracket.jpgMatt
1998 Mystic Teal Camaro M5
Yes, I realize that but i'm having trouble removing the bracket.
But that pic you posted helped a ton, i'm going to try and run my hand back there and get off that other bolt. Then when i get that hoe off, i'm throwing it in my tool chest for good. :mad:-1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
Originally posted by Fredless:
Then when i get that hoe off, i'm throwing it in my tool chest for good. :mad:Matt
